SgtWookie - thanks, that makes much more sense about the diode! However, I have tried putting the schematic together, reversing the pin 5 diode as suggested, but am still getting 6VDC out of the transformer (with 6VDC in).
I have tried two transistors, a BC141 and a 2N5551, both with the same result. If I remove the transistor altogether, the result remains the same. My circuit is pictured below - same attempt from two different angles:
