does this help?Need a bigger picture of the whole thing..
is this better?Need a bigger picture of the whole thing..
Transformer says input 240V / output 12V ..is this better?
Hi Keith,it is for pest control(rats and mice,it works by giving the rodents a low voltage shock through metal rails surrounding a building.You did not tell us what the complete device is or what it does. I do not recognize it. It would be easier to help you if you gave some clues. Is it working ? If not, what is it not doing that it should do?
What ever is potted in the large plastic container is probably not a transformer or a battery but without more information, we can only make wild guesses.
Regards,
Keith
The only markings was a sticker with a code 14410076D1 no product name or manufacturer,so i have searched and come up with nothing.Transformer says input 240V / output 12V ..
What are the markings on the other Transformer that looks like it's connected to the speaker terminals?
The potted device in the plastic box will be a high voltage pulse transformer. You should be able to measure the continuity of the primary winding which is the two wires that are disconnected from the circuit board. It should have a fairly low resistance. The resistance of the secondary winding, the two wires that go to the output terminals, should be quite a bit higher than the primary.Hi Keith,it is for pest control(rats and mice,it works by giving the rodents a low voltage shock through metal rails surrounding a building.
what would be your wild guesses...im stumped on this part.
Thanks Keith,if i need to change this product i have no idea where to start as there is no product name or information other than a number 14410076D1 and when i type that into a search i get no information,so how would i source such a product?The potted device in the plastic box will be a high voltage pulse transformer. You should be able to measure the continuity of the primary winding which is the two wires that are disconnected from the circuit board. It should have a fairly low resistance. The resistance of the secondary winding, the two wires that go to the output terminals, should be quite a bit higher than the primary.
Keith
I will assume that the device has stopped working. Have you made any tests on it ? If so, what have you found?Thanks Keith,if i need to change this product i have no idea where to start as there is no product name or information other than a number 14410076D1 and when i type that into a search i get no information,so how would i source such a product?
I will try to test very soon,and thanks again for your help.
