A small 15W or 20W non-temperature-regulated soldering iron is just ok for getting started. The problem is that it's too hot sitting idle and starts to cool down once you start using it.
You will find a temperature-regulated soldering iron does a much better job.
As you have found out, a 15W or 20W iron may not be hot enough to solder large components. You may need to go to a 25W or 35W iron.
For very large components or large ground planes that sucks away the heat I sometimes have to resort to a Weller 200W/260W Soldering Gun.
