is that a different set up from the circuit drawing?
i'm compairing the two but i'm confusing myself with the switch being at the opposite side,lol
Switch||715|150|2||SW?|1||2|SW1||switch_212
Note||742|294|1||||1||Cut trace||NOTEPAD_11
Note||862|288|1||||1||Battery+||NOTEPAD_11
Note||863|316|1||||1|| Battery-||NOTEPAD_11
Resistor|750000|292|208|1|Resistor|R?||1||IC||
Resistor|240000|292|235|1|Resistor|R?||2||IC||
Note||193|234|2||||1||250k Pot||NOTEPAD_12
Wire||371|212|11||11|#FFFF00|1|11|||
Capacitor|10nF C2|440|271|2|Capacitor|C?||1|1|||cap_112
Wire||398|240|11||11|#CC6633|4|11|||
Note||143|284|2||||2||Jumpers to center rails on board bottom||NOTEPAD_22
Capacitor|0.1uF|307|299|2|Capacitor|C?||1|3|||cap_312
Capacitor|100uF|549|299|2|Capacitor|C?||1|3|||cap_312
Capacitor|330uF|485|271|2|Capacitor|C?||2|3|||cap_322
LED|0|573|269|4|LED|LED?|4|||IC||led_44
Resistor|560|607|245|2|Resistor|R?||1||IC||
Wire||586|212|11||11|#FF0000|1|11|||
Resistor|100|373|400|1|Resistor|R?||1||IC||
Resistor|1000|400|372|1|Resistor|R?||3||IC||
IC||335|270|1|555|U?|||DIP8|IC||DIP8_1
Wire||332|242|22||11|#FF0000|2|11|||
Wire||426|297|23||11|#FF0000|3|11|||
Wire||332|324|22||11|#000000|2|11|||
Transistor|BC559|479|388|2|Transistor|Q?|||1|IC|EBC|transistor_12
Wire||425|212|11||11|#000000|1|11|||
Wire||477|324|21||11|#000000|1|11|||
LED|0|533|339|1|LED|LED?|1|||IC||led_11
Resistor|560|561|400|1|Resistor|R?||2||IC||
Wire||638|297|21||11|#FF0000|2|11|||
Wire||533|377|13||11|#A233C3|5|11|||
Note||572|362|2||||1||Piezo+||NOTEPAD_12
Note||678|342|1||||1||Piezo-||NOTEPAD_11
BREADBOARDSTYLE=BB53
Nope, the circuit is the same, it's appearance is dependent upon the board layout. Either Sgt. or I could have easily placed the switch on the left. Just comparing his design and mine but with different layout makes a bit of difference. A lot depends on part placement too.is that a different set up from the circuit drawing?
PEBBLE takes a bit to get used to. Most of it is pretty straight-forwards, but there are some subtle nuances to using jumpers to get them to do what you want to do. For example, you can't directly run a jumper diagonally, but you can use more than one jumper with "insulated ends" to create an L-shaped or zig-zagged jumper. The offsets can help you make a layout more clear where you otherwise would have had to run jumpers over the top of each other.Go ahead, show me up Sgt. Might as well stick with what we know best. It was my first time with the software.
Just figured out how to make a cap vertical! I'm a genius!PEBBLE takes a bit to get used to. Most of it is pretty straight-forwards, but there are some subtle nuances to using jumpers to get them to do what you want to do. For example, you can't directly run a jumper diagonally, but you can use more than one jumper with "insulated ends" to create an L-shaped or zig-zagged jumper. The offsets can help you make a layout more clear where you otherwise would have had to run jumpers over the top of each other.
If more than one object is occupying the same space, the last one placed will be on top.
Borderline.... It's the LED that will be on throughout the timing duration, might as well leave it at 1/2W.The red LED's resistor should be 1/2 Watt, but if the blue LED's Vf is ~3.4-3.5v, then it can be 1/4 Watt.
Did you order the bread board or the prototype board that I suggested?I've ordered all the parts once they arrive i'll get started to the circuit and get the pics posted up. Hopefully it'll work ;-)
The negative lead is the shorter of the two. Yes.I ordered the breadboard that requires soldering.
I've started the circuit however I've never soldered/used a Capacitor 330uF. Does the short stem get wired to the negative side of the circuit?
Can't answer that with any certainty.thats what I thought thanks. Is this the same rule for all components?
apologies bumping this thread. just windering if this project was coHere is the breadboard layout, which may be comparable with the proto board you ordered.
Verify anyone please!
Pebble file txt:
Thread starter | Similar threads | Forum | Replies | Date |
K | 8085 Assembly Language RIM Command Help Needed (Resolved) | Programming & Languages | 5 | |
C | Dc cnc retrofit help needed | Power Electronics | 15 | |
How to make my delay relay circuit latch? | General Electronics Chat | 2 | ||
R | Button delay help needed | General Electronics Chat | 4 | |
M | 555 Delay circuit - badly help needed | Digital Design | 4 |
