HELP needed on 37LF65 Lcd Tv problem
Welshy_Pete
Joined Nov 5, 2011
17
Hello Ive got a 37lf65 lcd tv. The tv switched on and works fine the picture as it should. Then after afew mins or so it will start clicking or poping sounds then the screen goes blank. But the tv stays on the green light but then no sound or picture.
If I switch the tv on and of it will work fine but then do the samething again. But will do it more faster when it gets warmer.
Ive tried anther mains cable but its still the same problem.
Just wandering is this the part power board needed or something else gone?
thanks pete
sheldons
Joined Oct 26, 2011
613
ok failure could well be power supply related-there may also be a chance of a fault to do with your inverter-worst case may be a failing backlight assembly(insulation problems occur here with the wiring used)
faults like this can also cause corruption with the sets nvm as well which can cause some very weired faults.
sheldons
Joined Oct 26, 2011
613
you need to check the smps for hi esr and bulging leaking capacitors as a start....they will be obvious to spot.....
sheldons
Joined Oct 26, 2011
613
basically lie the set screen down(if you dont have a servicing jig)on something soft like a blanket etc and examine the power supply for overheated bulging capacitors-which will be easy to spot.....always replace these with hi temp types to stop repeated failure and replace with a higher voltage (some sets use 10v rated capacitors on a supply rail of some 12v dc-which do fail after a while)do NOT connect any test equipment(along the lines of a scope etc)without using an isolation transformer....quick tests with yr multimeter will be fine
Welshy_Pete
Joined Nov 5, 2011
17
Just anther update I left the tv of all night and unplugged. Just plugged in back in the Tv stayed on for 25mins also the room cool with the window open. Once it got warm it started again. Switch it back on and it would go of within 30 seconds.
Ive taken the power board out and thinking of getting it checked out then a replacement one if found faulty.
So this is deffo a heat related power board problem now?
__________________
Welshy_Pete
Joined Nov 5, 2011
17
Ive checked the capacitors on the main power board and the all look fine. None have any leaks or bulges or domed either.
sheldons
Joined Oct 26, 2011
613
ok have a look on the invertor board....and check each invertor transformer with your dvm and see whats happening with them
Welshy_Pete
Joined Nov 5, 2011
17
LCD TV Troubleshooting
The defective LCD TV may have the following common symptoms:
Symptom: No picture on screen but LCD TV still has sound.
Solutions: The problem is cause by defective inverter. Replacing ivnerter will solve hte problem.
Symptom: Screen flash on and off between 1/2 to a few seconds, but power indicate light stays on and TV still has sound.
Symptom: Blue Screen but no picture
Solutions: The problem is cause by defective Main Board(AD Board). In some cases, this problem may cause by the defective Screen Controller board. Thsi board is mounting on teh back of LCD TV Screen.
Symptom: Power light stays on but no display and sound
Solutions: The problem is cause by defective Main Board(AD Board) or Power supply board.
Symptom: No Power or Power indicate light does not lits
Solutions: The problem could cause either by defective Power supply board or defective Main Board(AD Board).
Symptom: Screen is half dim and half bright
Solutions: The problem is cause by defective LCD Panel.It needs to be replace.
link
http://www.lcdparts.net/panelledkit.aspx
Welshy_Pete
Joined Nov 5, 2011
17
link
Mine is that
But mine works when cool for 25mins then goes of. Then when switched back on goes of faster warmer.
So the power supply board which I know of. But whats the main board ad board????
sheldons
Joined Oct 26, 2011
613
ok have a look in the service manual page 53 that is the board you need to look at....it may be useful if you have a hairdryer and heat various components up and see if the fault clears then use some freezer spray to cool the component down again...it could still be a hi esr or oc capacitor but also it may be soldered joints or a fault with the backlight assy itself
sheldons
Joined Oct 26, 2011
613
do not heat parts up while the set is on by touching them with the tip of your soldering iron or things will go bang(without the use of an isolation transformer)
Welshy_Pete
Joined Nov 5, 2011
17
Please..please post pictures before u go on. This would help in telling u where to look.
Ive had a look on the back of the soldered joints and there metal parts which stick up. Then there small parts of metal missing this could be the problem. Ive cleaned the back of the mains power board. I will post some pictures on here to show what you all think.
Welshy_Pete
Joined Nov 5, 2011
17
Just looked at the back of the psu board and the solders have bits missing on them. I think this could well be the problem. Also maybe faulty capicitors. But the broken solderder links would cause problems?
I will post some pictures now best I can.
R!f@@
Joined Apr 2, 2009
9,918
Sorry mate. I cannot see any issue there.
U need to post complete board and take the picture perpendicular to the board.
I need to look at both sides
