It may have gotten jammed in there. If you look very carefully on the front there will be a very tiny hole that you can stick a straightened paper clip in and manually open the door enough that you can grab it and finish opening it by hand. If the CD is jammed you'll have to bounce it back into place.
If it continues to be a problem most of these have a tiny rubber belt in the door open/close system that breaks or wears out.
