OK, now figure out how to start the motor out stepping slowly in one direction, and then increase the speed smoothly and gradually to a much faster speed (less time between steps) - and then after running at full speed, slow the motor gently to a stop.
Your routine should be able to accept a number representing the total number of steps to take in one direction.
You should also post your schematic and the code you used at this point in order to have some record of your progress. If you don't post your schematic and your program code, it will be much harder to suggest where to go from here.
