Hello Everyone!
Refer to the subject, please guide me in a situation, there is a power cable 25sq. mm, 4 core pvc/pvc non swa buried directly in ground and in some ducts.The cable has damaged anywhere and it shows short circuit between every conductor. I have tested with a uni-T multimeter, it shows almost 2 to 3M Ω resistance between each conductor.The operating voltage is 3 phase, 415volt, 50Hz
Please suggest me a technique to sort this short circuit out, without digging the all area and ducts underground about 2.5 feet beneath .Is it possible to locate the exact location of the leakage area?
Can we built an circuit Electronic circuit for it with Wheatstone Bridge?
Your opinions are requested in this regard
