The capacitors shouldnt read as a short. If you removed the rectifier & its not shorted, then remove the switching device. It maybe a transistor or a MOSFET, two totaly different devices. If its a transistor check for a short betwean the colector & emitter. If its a MOSFET check for a short betwean the drain & source. You dont give very mutch info on what your looking at, which makes it hard to give any advice.
