Completed Project Help! How to identify the wiring from an NL-F570 Sanyo Fluorscent Emergency Lamp circuit?
Rahulk70
Joined Dec 16, 2016
533
I recently got the circuit from a Sanyo Fluorescent emergency lamp.The one in my lamp was damaged long time ago.Thought its a good idea to put it back together.Only when I began soldering did I notice that there are 6 output wires from the circuit labeled as PL1,PL2& PL3.There are two sets of PL1,PL2&PL3 outputs. All the previous fluorscent emergency lamp I had fixed in past usually had only two wires.I'm kinda confused.
Dodgydave
Joined Jun 22, 2012
10,692
Then one set of wires will be for the Krypton bulb, the other two sets are for the cfl tubes,
Use a Voltmeter to check the cables, the Krypton wires will be about 3-5V,
the tube supplies will come from the inverter transformer with a series capacitor, and will be around 150-230Vac
Rahulk70
Joined Dec 16, 2016
533
Thanks. I'll check it out. Initially I was hesitant to connect the multimeter to the leads since a person told me the output to the tubes are high voltage.Just wanted to be sure I didn't damage anything.
Rahulk70
Joined Dec 16, 2016
533
Sorry for the noob question.In the image above (IMG_0232) what is the white -red colored component with black leads in between those two transistors?
