I have this thermal printer main board that isn't working. The separate power supply that provides 25V and 5V is fine. I have narrowed the problem down to this power MOSFET. It took a while (no thanks for the dumb minimal marking, DI), but I found the datasheet.
I believe that since I have 25V on the (red) source pins and 24.5V on the (orange) gate pin, there has to be 25ishV on the output, but there's -0.2V (blue). The SOIC8 chip that blue leads to is a DC-DC converter that creates the 5V power rail and further on 3.3V. Since neither of these voltages are present, logically nothing works. The 5V output from the power supply board is a separate 5V rail for something else. It does not power the logic.
There is nothing even remotely burned or damaged on this board. Schematics are non-existant, so I'm just following traces and trying to make sense of it. Is there an in-circuit way to definitely measure that the MOSFET has failed internally and needs to be replaced?
![IMG_9667.jpeg IMG_9667.jpeg](https://forum.allaboutcircuits.com/data/attachments/293/293921-8b1cadf454c169c1803075fa2dd8e18c.jpg)
