It is getting out of step, I was writing it off as over run and such, but I wonder if it is the sensor. The original rotor motor ran in the 6000-6500 rpm area. The motor I am using is 1526 rpms, but I used an 8 pole magnet instead of the 2 pole that was on the original. So the sensor should be seeing 6104 rpms.You should be able to cycle several times to see if it gets out of step.
The old satellite actuators display the count.
The hall effect sensors were very sensitive to adjustment.
Also, I don't know if you are running at the same speed as original counter.
If it's like the sat. actuators there will be a narrow window of pulses per minute that it will respond to.
They ignore others as noise.
