I'm having a bit of trouble with a project I have going on. I'm installing a key switch on the outside of my bus, so I don't have to walk around and climb over the driver seat every time i want to open the doors. (other switch is on the inside)
Right now the circuit has one double pole double throw switch that goes into what i think are two relay switch things , that are hooked up to the 12 volt DC motor that opens and closes the door. I wanted to put another switch into the circuit. (key switch for outside) I Have the switch wired up what i feel is correct. but if i hook up my switch the other switch stops working.
This is the switch I'm trying to put in.
http://www.apem.com/pdf/JD_series.pdf
I've also included what I feel to be a horrible diagram of what I've done.
http://dl.dropbox.com/u/2100166/bus door wire diagram.gif
sorry its not the most interesting project but, I'd like to say thanks to anyone who could lend some info and help me out. Much appreciated.
