MaxHeadRoom
- Joined Jul 18, 2013
- 28,702
If you short the two conductors together and attempt to spin it The greater the resistance the greater the field.
that was a exemple, not of real motor tomorow i will open the motor and take it pictures and i will try to open the second motor too for cleaning and take pictures.Appears clean and in good condition!
Hello my friend can you help me with the retifier part they don’t have gbj2506 and give me a rs3506m but mosfet blow with rs3506m and a new capacitador install I think since capacitador are the some value only the rectifier was different and since gbj2506 the diode test are okay is better use the old or rs3506m can be used?Appears clean and in good condition!
Hello and thanks again I replace the gbj2506 with rs3506m and capacitador and my mistake don’t test with motor disconnect , I test with all connect and fuse of the houses blow and 1 of the mosfets die too, so maybe I replace the rectifier the 2 mosfets and. Fast diode fep30jp and test with a 220v bulb then with motor connect and hope the fuse don’t blow anymore I’m far from home only return tomorrow the parts arrive this week. Thanks for your help a big thanksThe rating for the RS3506M appears to be higher than the original. So should not be the issue.
Did you try replacing the Bridge rect. and testing with the motor connection removed.?
Ok thanks for you help I will try to find a store that have a wires of that size I will count the length of the coils and I will try to repair my self but first I need to know the value of a especialize repair of the motor so I know if diy or send for repair, thanks for your great helping tanks again. Father motor repair I will put the resultsThe 750w may be under-powered for that particular TM!?
by Jake Hertz
by Aaron Carman
by Duane Benson
by Aaron Carman
