Well this is a section of the forum named "Education" and this wasn't pre-prepared pop science spoon feeding. These discussions amongst experts are informal and often shed light on how different people perceive differences, they also typically give insights into the history and view held at the time, all of this is an important aspect of science education.And you posted this link....because?
OK, that answers my question. Sometimes there are links with no explanations.Well this is a section of the forum named "Education" and this wasn't pre-prepared pop science spoon feeding. These discussions amongst experts are informal and often shed light on how different people perceive differences, they also typically give insights into the history and view held at the time, all of this is an important aspect of science education.
I enjoyed Fay Dowker's explanation (at 6:32) of Heisenberg taking empirical data and using that to define a precise way to predict probabilities and energies. Where he realized that the position of the electron can be represented by a matrix which gives rise to an analog of the old Newtonian laws of motion, I'd never heard it explained this way before and it was interesting to hear of the history of these ideas.
Bragg does a superb job too of asking layman questions, often pushing the guests to explain things in different ways to an audience of intelligent listeners but who are nevertheless not experts in the subject.
Apologies, I can see how that looked now, just a URL, hardly helpful!OK, that answers my question. Sometimes there are links with no explanations.
No, you can get precise statistical information about a large collection of particles. This has nothing to do with the uncertainty principle.This means that if you do the experiment enough times, you can get results that are very precise, and the means you can measure everything about a particle.
Maybe you are thinking of the 2012 Nobel Prize awarded to David Wineland and Serge Haroche for their work in using photon traps to make non-destructive measurements of the trapped photons using large atoms.The idea here is that the more experiments you do, the more precise the measurements get, and that's the basis of statistical measurements. This means that if you do the experiment enough times, you can get results that are very precise, and the means you can measure everything about a particle.
It has nothing to do with the uncertainty principle to YOU (sorry to seem so abrupt with this).No, you can get precise statistical information about a large collection of particles. This has nothing to do with the uncertainty principle.
Hi,Maybe you are thinking of the 2012 Nobel Prize awarded to David Wineland and Serge Haroche for their work in using photon traps to make non-destructive measurements of the trapped photons using large atoms.
The technique allows for non-destructive interaction and measurement, something usually not possible because measurement causes decoherence—”wave function collapse”. This is more relevant to Schrödinger than Heisenberg—though it is very important and something that previously seemed impossible.
To the extent it is decoherence that prevents the measurement of both position and momentum (for example) this work may be relevant, but so far as I know, no one has found a way to circumvent Heisenberg’s principle.
This is much more complex than would be elucidated by any intuitive or cursory examination.
I stand by what I said. If you don’t understand it, that is not my problem.It has nothing to do with the uncertainty principle to YOU (sorry to seem so abrupt with this).
This is on the quantum level.
Keep in mind he was back around the late 1920's, a lot has changed since then.
Of course even if you do that you aren’t measuring the two with equal precision at the same time. Which is what Heisenberg says. You are measuring each at different times, and not avoiding the decoherence, just measuring a time-differing twin.Unfortunately, that's not the original article I read either which I think I can sort of explain a little. It read like it came from the fact that one of the laws of physics that says that there is no difference between one electron (or some other particles) and another. There is no distinct identity. Taking that to the extreme, an experiment was performed where, basically, they could create the EXACT same experiment as many times as they liked, and it was exact in every possible detail. What they did basically was then measure the two quantities, but only one in each of two experiments (actually more than that), and because the experiments were quantum exact, they could measure both quantities perfectly.
It's sort of like hitting a pool ball into a corner pocket, and measuring the speed, then shoot another one with the same weight and same force into the same pocket and measure the position as it rolls (or maybe the spin). That's of course not the same thing but just an illustration because with objects like these there is bound to be uncontrollable fluctuations, but with particles that have no identity the path and everything about the particles could be made to be exactly the same.
Note when we talk about this stuff we also have to talk about the date.
Hi,Of course even if you do that you aren’t measuring the two with equal precision at the same time. Which is what Heisenberg says. You are measuring each at different times, and not avoiding the decoherence, just measuring a time-differing twin.
Hi,I stand by what I said. If you don’t understand it, that is not my problem.
Some of us are, others are not.Hi,
Well thank you, but with all due respect, and I say that sincerely, I could say the same thing to you.
This happens because we are doing what Ya'akov suggested: talking casually about a very deep topic.
Hi there Wendy,Guys guys! Don't make me put a time out on this thread!
\ rant
