@The Electrician: I sent you a private message. Please check it.
I had a Kenmore that did this. Turned out to be a melted micro switch that should shut the unit off when the door opens. These are usually overloaded since the one I replaced was only rated 5A. Less chance of failure if people let the unit shut off by internal relay control before opening the door.I have a Samsung model SMH9207ST OTR microwave oven that is about 4 years old. Everything works fine except the mw oven now turns ON by itself when you open the door?? (Inside light and fan come on - not sure if it is microwaving). Weird! Any suggestions on what is most likely wrong would be appreciated.
by Aaron Carman
by Jake Hertz
by Jake Hertz
by Aaron Carman
