The heating pad element has been cut into 12, 16", sections. One inch of plenum removed from each end and ~ 1/2" of insulation was burned off using a lighter. This exposed the wire with was twisted around some sort of a multi-stranded fiber.
I guess I should clean the exposed wire ends with flux? None on hand, so it might be a little while before I can continue.
Ran into a non-sticky problem--'super glue' didn't adhere to either the plastic insole or the wire Twist ties, sewing thread, or fishing line might work to tie them down.
