I am designing a PCB and am using a 3mH air core inductor which is physically large (about 6cm diameter, 3cm depth) so i was intending on mounting it underneath the board with other components above it. One of those components will be a hall effect sensor... i was wondering if the magnetic field of the inductor would affect the field in the hall effect device and result in erroneous current readings? The maximum current will be ~3A and the hall effect device is planned to be located in the centre of the inductor coil (right in the path of the magnetic flux argh!)
*edit: not sure if its relevant but the hall effect sensor is the Allegro ACS712.
