It needs to be a MosFet transistor.i should have most of these parts. will any 2N transistor work? i dont believe i have that exact part.
You can use 2 in series.and on the zener diode, i see you have a 10V, i have 5V zener's here, is it possible to use those in a different arrangement?
It is just on ( 0 volts) when the engine is running, or off (5v) when engine is not running. Are you looking for a linear output based on RPM?i know you mentioned about not knowing the amount of turns needed. saying that, is the output of the circuit limited in any way? or is it linear with the input just smoothed out?
Not sure which one. Most of those output a pulse when the plug fires and the micro calculates RPM based on the number of cylinders.if its varying voltage from the input, could we use that 2nd schematic i posted with it? ive tested that and it works nicely and has a 0-30V usable input.
The current in the secondary circuit is tiny - a few ma. plugs leads are also notoiously leaky and you run the risk of frying something with a bad lead or damp weather. You don't really need an inductive clamp, just wrap a few turns of light guage insulated wire around the plug lead and you will get a good pulse. Ground one end of it to protect your circuit.i was under the impression that a magnet wasnt required? that the dc current gave enough radiation off for the hall effect to determine the current?
like this sensor:
http://www.dfrobot.com/index.php?route=product/product&product_id=580#.Ui5GTz-wUec
Yes, the lower rail is ground.i guess the lower rail is the ground, but whats that gate tag, and what component is V1? and is there a +5V for the transistors anywhere coming in?
V1 is just for the simulation, it represents the voltage picked up by the wire wrapped around the plug wire.
The 5 volts for the FET is shown as a battery on the right.
Use the NTE491 in your link.
The gate tag is just so you can see what point is plotted in the simulation. If you look at the waveforms you can see they match the tags.
