I am working on TL072 IC, I need expertise of experienced people in the following:
again the same question as point 1.
- 1. In page 10 of data sheet the common mode voltage is mentioned as VCC- +4 to VCC+ does it mean the allowed input range of inputs are +4 to Vcc+ ( could be 12V or 15V ) or does the range mean allowed input voltages are, lets say rail voltages are +12V and -12V so the allowed input range is -12+4 to 12V i.e., -8 to 12V ??
- 2. I need to wire this IC as voltage follower/unity gain circuit, is it mandatory to use 100pF or I can change to 2.2uF ( Page 25).
- 3. Page 29, 8.3 as per the data sheet there is no -vcc and it is connected to ground so practically if i give -vcc instead of connecting it to ground does the circuit function or it works abruptly ???? . also, it is mentioned in the data sheet as follows:
- Input voltage must be within the recommended common-mode range, as shown in Recommended Operating
Conditions. The valid common-mode range is 4 V to 12 V (VCC– + 4 V to VCC+).
