I see now that my choice of words in my previous post was incorrect. I understand that the bond, under normal operation, should have no current flow and is solely for safety purposes - in theory, everything will work as designed without these connection points. Neutral, on the other hand, is ~24VDC or ~85VDC (in my application) less then the hot lines and is the return path for their respective currents.I think you need to polish up your definitions of neutral and bond.
Some questions:
1.) Do all DC sources and component bond connections need to be fed back to the incomming AC Earth Ground connection point on the metal plate or can I assume the conductivity of the metal plate is enough?
2.) Should I physically connected all instrumentation wire shielding to a common point on the metal plate? Furthermore, should I physically connect these shields to the common point as noted in question 1?
3.) The driver I am using (Oriental Motor part #RBD245A-V) has two power connections. They indicate one as '+' and the other as 'Ground' which is indicated to be connected directly to an Earth Ground Point. This setup does not seem logical as current flow is not directed back into the DC source.
Please correct me if I am wrong!
I do have a few more questions but I think that is enough for one night
Thanks for all the comments and suggestions!!! You Electrical guys ain't to bad after all!!
