The list of AVRs that can be programmed by the AVRISP MKII includes almost all of the ATTINY and ATMEGA AVRs.Hello hgmjr
What do you mean here:
'The programmer you have purchased will work with pretty much every AVR in the 8-bit family'
What is the 8 bit family, on ebay it had a table of all the chips and there was ALOT of them, so this means that my 6 pin header thing from the AVRISP MKII can program all the chips, ATmega328p etc
Chris
Check out the tutorial at www.avrbeginners.net for an introduction to assembly language for the AVR processors.Also What is assembly language and C language, can you give a brief example of each?
The example you have indicated is a few lines of code written in C-language.I have watched tutorials on youtube of people making LED's Dance like Knight Rider etc, and they write a code like,
#include <avr io.h>
{ while(1)
_delay_ms(250)
You can find a number of good C-language tutorials on the Internet. You can also find some sample C language programs written for the AVR all around the Internet as well. You may want to register at www.avrfreaks.net. They have a lot of knowledgeable people there that can assist you with any AVR questions you may have.ETC, that sort of code, i understood a litle bit when the guy said that 1 means the LED will be on and 0, 0 means the two others will be off
Where can i learn that type of code, and wat is that called
If you have a program that you are developing you can always post it here between code tags for cleaner presentations.Oh yes i have Win AVR, i was playin with it last night, i was watching a tutorial on writing, and i made a code it all worked, but im not sure if the code i was writing was going to do, but more importantly once i made the code, and compiled it into Hex, can i add that to any chip, for example if i made any random hex code and programmed it to my ATtiny13A would it work?
Quick Question, What Chip could i use to program a sound that ran for about 3-5 seconds, chip that has enough memory?
Chris
I would be willing to bet that the programmer created a set of tone loops and then called them in the order and duration needed to produce the simple tune. I doubt an MP3 file was involved.Ohk, right now i have been looking at tutorials on C programming and it becomes alot more easy to understand but it is still really hard to make my own program. At this stage, i am happy to make projects like the one i already made, where i just download a hex file and buy the chip then program it. Thats why i wanted to know how the person made the nokia tune, did they have to write the C code for the tune, or did they get an mp3 and put it into a mp3 to hex converter?
Chris
