Got china camera no name need help unstanding the manual see pictures
mrel
Joined Jan 20, 2009
185
Hi
Does anyone own one of these china camera has no name .
Camera come in red and gray box.
Manual title ( Ca series HD analog Dome camera quick operation guide)
Try contact seller, seller don't answer email.
Enclosed is pictures of the manual.
If someone own this camera ,can you explain what is the numbers in manual mean.
See circle numbers in red.
Are these numbers to setup the camera?
mrel
IMG_20200913_054852.jpgIMG_20200913_044011.jpgIMG_20200913_044052.jpgIMG_20200913_044129.jpgIMG_20200903_044101.jpgIMG_20200903_044128.jpgIMG_20200903_154145.jpg
KeithWalker
Joined Jul 10, 2017
3,098
Showing us those settings is like showing us a page from a novel and asking us to tell you the story. What other information is in the instruction book? The more clues we have, the better guesses we can make.
Regards,
Keith
mrel
Joined Jan 20, 2009
185
Regards,
Keith
Here is the complete manual the earlier pictures is part of the manual ,see attachment.
KeithWalker
Joined Jul 10, 2017
3,098
The tables of settings that you showed in your first post are the commands to enter using the analog control board to control the camera. Do you have an analog control board? If not, how do you intend to set up and control the camera?
Regards,
Keith
sagor
Joined Mar 10, 2019
912
Picture of manual shows a RS485 serial interface. I suspect the commands are sent over that serial link. Not sure at what speed however...
The Analog Control keyboard is the missing piece of information, that device has the information as to RS485 protocol and speeds, etc.
mrel
Joined Jan 20, 2009
185
Hi Keith Walker,Sagor ,thank for your reply.
You mention tables of setting command (numbers) is for using analog control board to control the camera.
Enclosed is two pictures of cctv joystick keyboard controller.
This pictures of joystick keyboard this consider analog controller board as mention in your post?
If joystick as picture is controller,i don't really know how to use this joystick the manual not clear, on how put numbers in to control the camera.
KeithWalker
Joined Jul 10, 2017
3,098
That is not quite the same as the analog controller that is shown in the camera manual but it appears to have all the same features. Do you have a manual for it? If not, does it have the manufacturer's name and a model number on it? Then you can use that to find the operating manual on-line.
I have never used one of these, so I really can't offer any more help than that.
Regards,
Keith
