In this case it just allows for the adjustment of the circuit within the fullest possible range. Dropping that maximum down to 1M the output signal only achieves about half of what would be possible otherwise.I have seen 1Meg i think. Why would you need such a thing?
Unfortunately the series resistance (or otherwise the lowest setting on the rheostat) needs to be no more than 10K ohms or so.A series of 100M resistors with a selector and a trimming potentiometer might work
I don't think any potentiometer could be set to a value that is 1/10000 of the full scale value.Unfortunately the series resistance (or otherwise the lowest setting on the rheostat) needs to be no more than 10K ohms or so.
