Hello, my CGHV1A250F needs 15A and 45V(pulsed), I have found a SQ3426EV N channel mosfet which data sheet shown below.
I need to bias two CGHV1A250F with SQ3426EV.
However as you can see below when i put 47V on the drain i get about 45.6V which is Ok.
I will put Vgs floating to about 5V to be in the saturation region so small changed in Vgs will not ruin the bias point.
A Ltspice simulation was built ,the two CGHV1A250F represented as 1.5 ohms.
As you can see below wen my voltage is drain 45 i get 30A.
Is there some tunable gate driver like UCC5304DWVR which will be supplied by DB02S4812A but i could tune its with some resistor?
LTSPICE files are attached.
https://www.ti.com/lit/ds/symlink/ucc5304.pdf?ts=1715168342903&ref_url=https%3A%2F%2Fwww.google.com%2F
https://www.vishay.com/en/product/65107/tab/designtools-ppg/
https://pdf1.alldatasheet.com/datasheet-pdf/download/1673867/WOLFSPEED/CGHV1A250F.html
![1715173100499.png 1715173100499.png](https://forum.allaboutcircuits.com/data/attachments/309/309512-0ffda6c0aa000f966a9796a101b09862.jpg)
![1715165975149.png 1715165975149.png](https://forum.allaboutcircuits.com/data/attachments/309/309503-7f2454c8369a5decf3101b1cc0135e26.jpg)
![1715166030080.png 1715166030080.png](https://forum.allaboutcircuits.com/data/attachments/309/309504-a07907b3a622467fbb7c97c927847b3f.jpg)
![1715167093641.png 1715167093641.png](https://forum.allaboutcircuits.com/data/attachments/309/309505-73566f34625160da1455fff6fae5978f.jpg)
![1715167116846.png 1715167116846.png](https://forum.allaboutcircuits.com/data/attachments/309/309506-4123618a7d8e236c64aaa5efd49c3602.jpg)
