That would work.OK, back to the simple. How about a series of balls hanging from the ceiling which each one spaced to just touch the windshield of the vehicle you are driving when at the proper position. You could label or color the balls so you would know which ball to use for a particular vehicle.
I used a ball in my garage for that purpose where I ran the string through a pulley attached to the rafters and then to the top of the garage door. That way when the garage door was down the ball was pulled up and out of the way.
What is the input to the controller? A digital signal? Could you send them through an AND gate so that they BOTH must report clear? A NOT gate or two (or equivalent circuitry) may be necessary dependent on the controllers input requirement. Also, has anyone considered the possibility of transmitter A triggering receiver B? Could this be resolved by orthogonally mounting the sensors? Or using separate carrier frequencies?According to some internet postings, it is not possible to simply put another pair of sensors in parallel with the first. Apparently, the transmitter sends a square wave signal to the receiver, which tells the controller that there is no blockage. My assumption is that if I had two sets in parallel, it would essentially be an OR gate, and unless both sensors were blocked, the garage door would close. I need to think about this some more.
Well, you could put a few blinking LEDs on each ball.That would work.
But it doesn't have even one transistor.
Now, we're talking!Each auto has an RFID card inside. When it enters the garage, it tells an MCU to measure the appropriate distance to the car's front bumper. It overrides the garage door until the car is clear and illuminates an indicator light when the car is in position. Sensors, logic, transistors & resistors & LEDs, with an MCU thrown in for fun.
