Austin Clark
- Joined Dec 28, 2011
- 412
You can add any two-bit numbers together.So you can't add 11+01?
So, yes, you CAN add 11 + 01
Your schematic is correct but the way you placed the numbers is wrong. A1, B1 are less significant and should be placed on the right. A2, B2 are more significant and should be placed on the left. Like belowThis is wrong... unless I am thinking wrong. Here is what I understood from you on this attachment, but it doesn't add up right.
B2 B1 1 0
+ A2 A1 1 1
5 1 0 1
But in your case the answer is "4".
I'm looking at your picture, where you wrote the sum as 100, it's actually showing up as 101. Also, the image you're using isn't my circuit. In my posted image, I have it layed out correctly, as you have typed.
Your schematic is correct but the way you placed the numbers is wrong. A1, B1 is less significant and should be placed on the right. A2, B2 is more significant and should be placed on the left. Like below
Then
AllenRich (BB code):B2 B1 1 0 + A2 A1 1 1 ---------------- 5 1 0 1 ---------------- But in your case the answer is "4".
Possibly Radio Shack (but getting less likely each year).Where can you buy the 4008? I have no idea.
Thread starter | Similar threads | Forum | Replies | Date |
Need help with 74ls193 | Digital Design | 12 | ||
Adding -A-B in a Full Adder | Homework Help | 2 | ||
Full Adder in Ltspice | Homework Help | 65 | ||
Logic circuit projects issue | Homework Help | 69 | ||
R | Designing a logic circuit using a full adder? | Homework Help | 7 |
