>I'm not sure what you mean by "vibration"?
Maybe I'm not precisely to describe the state that I want.
Because a floating pin is easy to generate a square wave, but the wave is unexpected, the frequency is in a astable state, and also easy effected by hands or some other signals, normally we called "Oscillation".
You are right, the first stage can be use half adder.>Actually, the first adder doesn't even need to be a full-adder.
>The first stage could just be what's called a half-adder.
>http://ustudy.in/sites/default/files/ALU_half_adder.gif
>It's less than half the size, and works precisely the same as a full adder with Cin constantly set to LOW, or 0.
Maybe aj88 just want to do the pratice, so he choose the logic gates.>Also, just to be sure the OP knows, there are ICs that contain full adders all-in-one,
>like the 4008 CMOS IC. http://www.doctronics.co.uk/4008.htm
