I have no clue why you insist in repeating something that is irrelevant. Yes, I e-mail files to myself. What about it?I have, however, taken what you have said to be true, so that you email files to yourself as a means of data transfer.
It's not as hard as you think. With a little effort, we can have technical discussions without the personal BS.ger scale, personal comments are impossible to avoid, everyone has preferences and, when there are multiple ways of doing something, those preferences are bound to show through. That is not to say that it is okay to make judgment calls on a person, just that their preference is whatever it is.
If that is true, why mention that you use it? If it should always be technical, you would not have included your preference.I have no clue why you insist in repeating something that is irrelevant. Yes, I e-mail files to myself. What about it?
Once again, you misquote. I never said it was my preference. Thus, you make this personal, not me.If that is true, why mention that you use it? If it should always be technical, you would not have included your preference.
That is the only place the thread becomes personal...
Are you joking!? YOU said that you use it! That makes it a preference!Once again, you misquote. I never said it was my preference. Thus, you make this personal, not me.
False logic. I use different tools depending on the circumstances. Not one is a preference.Are you joking!? YOU said that you use it! That makes it a preference!
So in transferring a file of 2kB, would you not prefer to use the email option, as opposed to getting an external hard drive?The logical fault is I don't use it as opposed to other methods. As I said, I use the appropriate method for the circumstances. It is merely an option, not a preference.
Agreed. This is my last post on such a petty argument.Ok guys, time to knock it off. Time to move forward.
Not so. I offered it as an option to the OP, and that was all I did. I don't get personal, and I require you not get personal with me.Regardless, you stated a personal use, something you have argued to have stricken from a technical discussion.
I must not be in that majority. If I were doing a computer move, my data transfer would exceed 700GB, and a sizable chunk of files would be in the 1GB+ range.You're extrapolating. What I've said time and time again is that <25MB is sufficient for an overwelmingly majority of user's file. I made no comment about my work. To clue you in, I have a work life and a personal life. I made no distinctions between the two. And I sure as HELL wouldn't be sharing my work over Yahoo.
From now on, I'd appreciate keeping personal comments out of our technical discussions.
All that the OP said was that he was transferring files, not moving computers. We don't know if those files are small or large. The option I gave makes no assumptions about file size, and is a fair option for most files a user would typically transfer (jpeg, .docx,. PDF, etc) It was only an option that nobody had yet mentioned. There is no reason for me to believe his files sizes exceed the 25MB limit, but if they do, then other options are available, as many other's have already mentioned.Given that the topic is (or was) about the OP moving computers, it is rather safe to say there is/was a lot of data to transfer.
But you are making assumptions about file size. You have stated explicitly that there is a ~25MB limit on file size, meaning every file larger then that is immediately excluded from that option.All that the OP said was that he was transferring files, not moving computers. We don't know if those files are small or large. The option I gave makes no assumptions about file size, and is a fair option for most files a user would typically transfer (jpeg, .docx,. PDF, etc) It was only an option that nobody had yet mentioned. There is no reason for me to believe his files sizes exceed the 25MB limit, but if they do, then other options are available, as many other's have already mentioned.
At times, using the internet to transfer files is the best option. For example, my lawyer sends me documents all the time over the internet. He is, in effect, transferring files from his computer to my computer. Since we don't have a 2,000 mile cat-6 cable to make a direct connection, and mailing any kind of non-volatile media would be too slow, then the internet is the only viable option. As I've pointing out, one can move alot of data with only 25MB, and so this limit has not hampered our business, and we've had quite alot in recent months.
I make no assumption about the OP's file size to transfer. My option was merely an option, as the others were.But you are making assumptions about file size. You have stated explicitly that there is a ~25MB limit on file size, meaning every file larger then that is immediately excluded from that option.
I don't think there is a best overall option. Circumstances will dictate the best option.My point was that the best OVERALL method of file transfer, in terms of ease of operation and decent speeds given a point to point transfer, is undeniably a flash drive or external drive.
600 miles gaps sometimes exists. I have a home computer network in Alabama and one in Florida. Also, an array of portable computers. Why not consider all options and all circumstances? No reason to create restrictions on the discussion.Yes, I understand your point and agree that email is a very viable method of file transfer, but it is slow, and not made for large transfers. However, no one mentioned it because there are faster and easier ways to do point to point transfers. We aren't talking about a 6000 mile gap between computers here.
My point is nothing like that. It's a simple and effective option.Your whole point is like suggesting dismantling a brick wall brick by brick. It works, but a bulldozer or wrecking ball would be faster and do it better. And that is ultimately what most people want.
by Duane Benson
by Aaron Carman
by Jake Hertz
