The most problem i am having is when i use the dragging technique or soldering dragging, since its fine pitch pins it bends them and damages them because of the dragging
Another problem is it makes alot of solder bridging with the fine pitch
When i use the solder wick to remove the solder bridging it lifts up the pads because of the heat and the solder wick can stick to the pads and lift them up , it gets way worse when i use 'liquid rosin flux" because its very sticky stuff
When i use "Liquid Rosin Flux" not kester 44 rosin solder its liquid it makes the fine pitch pins so sticky and messy
When i use NO clean Flux" it leaves a salty white sticky , it leaves a white residue and sometimes it appears to be conductive if bridging leads
When i use "water soluble flux" its much better and its cleaner
