Finding Mesh Currents
Dodgydave
Joined Jun 22, 2012
11,307
I3= 4mA
so 4ma *1k= 4volts dropped across the first 1K resistor leaving 2Volts across the 3 parallel resistors.
6V-4v= 2Volts across the 3 parallel resistors( 2k/2k/1k) = 2v/0.5k = 4ma
I1=2mA, so 4mA-I1=2mA, so I0+I2= 2mA
as they are both 2K each the current is split equally
1mA in each, so I0=1mA and I2=1mA
bretm
Joined Feb 6, 2012
152
Let's call the top resistor R1 and it drops V1, the left-most resistor R2 and it drops V2, the bottom-center resistor R3 and it drops V3, and the bottom-right resistor is R4 and drops V4.
From inspection we know V1 / 1000ohm = i3
We know that i1 = 2mA, so we can see V2 / 1000ohm = 2mA - i3.
On the right-hand side we can see V3 / 2000ohm = -2mA - i3
From the center node we can see V4 / 2000ohm = 4mA + i3
So all four voltages are in terms of i3. What value of i3 is correct? We know that V1 - V2 - V3 + V4 have to add up to -6V (look for the path). The only value that makes this work is i3 = -(2/3) mA.
Since 4mA = i2 - i3, we have i2 = (10/3) mA.
That means i0 = -(4/3) mA.
Dodgydave
Joined Jun 22, 2012
11,307
There must be MINIMUM of 4mA through the 1K resisitor at the top, as that is the highest current flowing in the circuit! ( the circuit wont work as its just theory)
ErnieM
Joined Apr 24, 2011
8,377
It sounds like you have made a conclusion before you made an analysis. I've run the numbers and arrived at the same answer as bretm did (he beat me to posting it so I did not bother).
