I'm designing my first ever circuit for a hobby project. I've a sensor that outputs in mV (1 to 2) and a controller with ADC. The ADC is 16 bits, VDDA = 3.0 V, Temp = 25 °C, fADCK = 1.0 MHz. Since the sensor voltage that is fed is to the controller is low I'm in a predicament! Should I use a low pass filter or a band pass filter in this application? Do you have a circuit that I can relate to? I've attached an example plot and a circuit that I cooked up with LTC6085. I wanted a single supply instrumentation amplifier that will work with low power consumption. Any advice is appreciated. Thanks.
