Isn't that basically acetone? If so you can buy that at the hardware store and still hold your head up high.Go down to the beauticians and get some nail varnish remover.
(Nail varnish is also an easy DIY etch resist)
thats an idea; would I need to build a IR box?Why not experiment with the photo part of it though? If it is coated and all?
The photo resist will not be cured. So it will wash of quite easy. Try gasoline, acetone or alcoholI got some copper clad PCB material I want to etch with ferric chloride but its labeled "Photo resist copper clad board" - can I do it?
oh, well I guess that idea was fun to entertain while it lasted. Newark sent it to me in a box wrapped in clear plastic; had I even known that it was light sensitive, I still would have had to predict that they wouldn't package it properly, and open the box in a dark room.This is basically photographic film, if it has been exposed to light it is ruined, and to use the board stock plan A (cleaning the resist off) is required.
So does mine...The stuff I've used has a peelable plastic layer over the photoresist, make sure you peel that off if you've got it
