OK, I've attached a sketch of a version using TLO72 opamps for everything (except the power amp!)
By using separate pairs for the two audio paths, you can remove all the reactive elements from the 'null' point. This should allow better than 50dB attenuation of the internal mic/ speaker routing, and effectively remove the feedback problem.
Remember this is not a circuit to remove acoustic feedback. As Audioguru has already described, that is not possible with opamps.
This circuit simply allows you to control the audio routing, so that you can effectively 'null out' the gain path from the microphone to the internal loudspeaker, and simply allow only the audio from the other unit to be amplified.
Using Cat 5 cable, you could use the other two pairs for DC supply, and some form of calling sounder.
The system would need a 12V DC supply, at about 500mA.
