Yes - that´s true. However, is this the aim of the capacitor?Or - Lower gain at higher frequencies.
Probably has something to do with differences in education approach. My explanation was a simple version of the way I learned it, and I've realized that my courses have been less theoretical and more practical than similar things I find online from other schools/sources.It`s really interesting to see how many different approaches are possible to explain the effect of this additional capacitor (frequency domain, time domain, loop gain, opamp´s gain roll-off, compensated voltage divider,..).
And all these explantions come to the same conclusion:
Improvement of stability.
Inverting or Non Inverting Op amps amplifier using Rin Resistor , Rf feedback resistor
At high frequencies the feedback capacitor's impedance is low, ESR is low, so it passes the high frequency but the Op amps gain is LOWER because the capacitor impedance and Rf feedback resistor is in parallel so the Gain is lower at higher frequencies?Didn't say you were wrong LvW, just that stability was not the question.The Caps Impedance at high frequencies is in parallel with the Rf feedback resistor which makes the Op amps gain lower?
OK - agreed.Didn't say you were wrong LvW, just that stability was not the question.
by Jake Hertz
by Jake Hertz
by Jerry Twomey
by Jake Hertz
