djsfantasi
- Joined Apr 11, 2010
- 9,163
Come the end of summer, there are many room fans out at the curbside for trash pickup. If the bearings weren't loose, I used to flush out the bearing with WD-40 while manually turning the blades. Sometimes, I'd use a needle drop of acetone after that. Then I'd oil the bearing with lawn mower motor oil. I'd get a couple of years of use before the bearings wore out too much.
