Question: if we have a
single-phase full-wave controlled rectifier, ac supply with 50Hz and VS=220Vrms, R=100Ω.
If I have a firing angle =33 degrees and a capacitor is shunted with R, analyse and estimate the resistor power dissipation for small values of C (the ignore smoothing effect), and for medium values of C and sufficiently large values of C (neglect output ripple)
Answer:
So I know that In any rectifier, the larger the value of any shunt capacitor, we will have a smaller DC voltage across R.
To answer this fully should just use an example calculation such as:
Vr = Vm/(2xfxRxC)
and different ranges of Capacitors from say milli to micro to nano Farad?
Is there another equation for power dissipation?
Answer:
Vr = Vm/(2xfxRxC)
