ESP12s A9g IOT Module GPS Tracker
ecallawevad
Joined May 7, 2021
I have been trying to write some code for the arduino ide, without success.
Don't know why it wont work.
The following sketch works by sending latitude and longitude to a phone via sms.
But i want it to use the gprs data from the sim card and send latitude and longitude parameters via http.
The a9g apparently supports the AT+HTTPPOST command, but i cannot get it working at all.
If anyone has any ideas on how to do it, i would be very grateful for your input.
#include<stdio.h>
#include<string.h>
#define DEBUG true
#include <SoftwareSerial.h>
#define BAUD_RATE 115200
#define A9_BAUD_RATE 115200
String phonenum="077512xxxxxx"; //Please change the xxxxxxx to your phone number
#define A9G_PON 16 //ESP12 GPIO16 A9/A9G POWON
#define A9G_POFF 15 //ESP12 GPIO15 A9/A9G POWOFF
#define A9G_WAKE 13 //ESP12 GPIO13 A9/A9G WAKE
#define A9G_LOWP 2 //ESP12 GPIO2 A9/A9G ENTER LOW POWER MODULE
void handleInterrupt();
void SendTextMessage(String message,String phonenum);
int A9GPOWERON();
SoftwareSerial swSer(14, 12, false, 256);
void setup() {
Serial.begin(BAUD_RATE);
swSer.begin(A9_BAUD_RATE);
for (char ch = ' '; ch <= 'z'; ch++) {
swSer.write(ch);
swSer.println("");
pinMode(A9G_PON, OUTPUT);//LOW LEVEL ACTIVE
pinMode(A9G_POFF, OUTPUT);//HIGH LEVEL ACTIVE
pinMode(A9G_LOWP, OUTPUT);//LOW LEVEL ACTIVE
digitalWrite(A9G_PON, HIGH);
digitalWrite(A9G_POFF, LOW);
digitalWrite(A9G_LOWP, HIGH);
Serial.println("After 2s A9G will POWER ON.");
delay(2000);
if(A9GPOWERON()==1)
Serial.println("A9G POWER ON.");
Serial.println("Enable the GPS");
sendData("AT+GPS=1",1000,DEBUG);
pinMode(A9G_WAKE, INPUT);//interruptPin
attachInterrupt(digitalPinToInterrupt(A9G_WAKE), handleInterrupt, RISING);
void loop() {
while (swSer.available() > 0) {
Serial.write(swSer.read());
// yield();
while (Serial.available() > 0) {
swSer.write(Serial.read());
// yield();
String GPS_position=sendData("AT+LOCATION=2",1000,DEBUG);
if( GPS_position.indexOf("OK") >= 0 ){
Serial.println("GET OK");
String LG=GPS_position.substring(14,37);
Serial.print("lg**********:");
Serial.println(LG);
SendTextMessage(LG,phonenum);
delay(10000);
// sendData("AT+CMGF=1",1000,DEBUG); //Set the SMS in text mode
String ATCMD="AT+CMGS=";
String cammand=ATCMD+"\""+ phonenum + "\"";
// Serial.println(cammand);
// sendData(cammand,1000,DEBUG);
// sendData(message,1000,DEBUG); //the content of the message
swSer.println("AT+CMGF=1");
swSer.println(cammand);
swSer.println(message);
swSer.write(26);
void handleInterrupt() {
Serial.println("An interrupt has occurred.");
String sendData(String command, const int timeout, boolean debug)
String response = "";
swSer.println(command);
long int time = millis();
while( (time+timeout) > millis())
while(swSer.available())
char c = swSer.read();
response+=c;
if(debug)
Serial.print(response);
return response;
delay(60000);
int A9GPOWERON()
digitalWrite(A9G_PON, LOW);
delay(3000);
delay(5000);
String msg = String("");
msg=sendData("AT",1000,DEBUG);
if( msg.indexOf("OK") >= 0 ){
return 1;
else {
Serial.println("NOT GET OK");
return 0;
int A9GPOWEROFF()
digitalWrite(A9G_POFF, HIGH);
delay(3000);
delay(5000);
return 1;
else {
return 0;
int A9GENTERLOWPOWER()
msg=sendData("AT+SLEEP=1",1000,DEBUG);
digitalWrite(A9G_LOWP, LOW);
return 1;
else {
return 0;
ecallawevad
Joined May 7, 2021
Im not getting an error. Its just nothing appears to be being received at the server. Its like the AT+HTTPPOST command doesn't do anything.
So what i am trying to achieve is to get it to:
1) Start up
2) Get the GPS Location
3) Send the GPS Location to an http server, in json format e.g. {"devicename:0100000000000002","lat":"51.263738","lng":"-0.767373"}
4) Go to sleep for a couple of minutes
5) Go to 1)
The adapted sketch is as follows:
Mod: Please use Code Tags.E
C++:
#include<stdio.h>
#include<string.h>
#define DEBUG true
#define BAUD_RATE 9600
#define A9_BAUD_RATE 9600
String server="http://test.test.com:8080"; //Please change the xxxxxxx to your phone number
String datatype="application/json";
String data="{\"devEUI\":\"0100000000000002\",\"data\":\"51.4637483,-0.7518383\"}";
void SendTextMessage(String server,String datatype, String data);
int A9GPOWERON();
void setup() {
Serial.println(server);
Serial.println(datatype);
Serial.println(data);
String msg = (server+","+datatype+","+data);
swSer.write(ch);
swSer.println("");
sendData("AT+CGDCONT=1,""IP"",""prepay.tesco-mobile.com""",1000,DEBUG);
sendData(msg,1000,DEBUG);
delay(2000);
if(A9GPOWERON()==1)
void loop() {
// yield();
// yield();
String loc=GPS_position.substring(14,37);
Serial.println(loc);
delay(10000);
String message="AT+HTTPPOST="+server+","+datatype+","+data;
Serial.println(message);
//AT+HTTPPOST="http://music.163.com/","text/plain","helloworld"
// swSer.print(cammand)+","+(server)+","+(datatype);
// swSer.println(message);
swSer.write(26);
response+=c;
if(debug)
return response;
delay(120000);
int A9GPOWERON()
delay(3000);
delay(5000);
return 1;
else {
return 0;
int A9GPOWEROFF()
delay(3000);
delay(5000);
return 1;
else {
return 0;
return 1;
else {
return 0;
ecallawevad
Joined May 7, 2021
Even if i strip out all of the power saving stuff and just set it to stay on, i still cannot get any data posted to the server. It appears to find the location, but at this stage i have just been trying to get a dummy reading sent through
