Microswitch has one common point , one Normally Open point & one Normally connected point.What is the vertical scale, 2V/div?
Do you have a 0.1uF cap across the supply pins on the op-amp, 555, and switch (with a 1k pullup resistor on the non-grounded switch side). The switch cap will reduce bounce and possibly noise, while the others reduce noise on the power rails.
I used first two points, so according to you I have to connect NC point to positive supply using resistor . And connect Capacitor across common point and NO point. OK?
