Electronic parts identification help?
nidzo
Joined Nov 2, 2013
4
I could use some help in identifying electronic part on the pic that says something like EDCEN or something like that. I am not sure what this is. To me it looks like a DIOD. The other one is A2719 Ic. I was changing a battery in the shaver but accidentally reversed polarities where this part started to smoke. These pictures are the PCB of shaver/epilator. Any help would be useful.
Image with both attached to the PCB.
http://imageshack.us/a/img703/8950/k71t.jpg
And both zoomed in.
http://imageshack.us/a/img822/8944/vs5r.jpg
Thanks in advance.
nidzo
Joined Nov 2, 2013
4
Well I already stated that is A2719. My question was about the other one that has EDCEN or something similar on it.
THE_RB
Joined Feb 11, 2008
5,438
Looks to me like the A2719 is the motor driver FET, and the diode would be the back-EMF diode across the motor winding (so it can be PWM'ed).
Neither part would be that critical, just replace the FET with a similar spec part and the diode with a common diode in that package. :)
nidzo
Joined Nov 2, 2013
4
Thank you for the answer. I am not sure what you mean by "(so it can be PWM'ed) and "the diode with a common diode in that package."What values (voltage? same as for A2719 or?) and what type of diode this is? Zener? Could you please be more specific. Thanks in advance.
#12
I believe he's calling the EDCEN a rectifier diode. Similar to 1N400x series. Just the basic, "enough amp rating" and, "enough voltage rating".
THE_RB
Joined Feb 11, 2008
5,438
Yeah sorry for the late reply but that's right. The diode type should not matter much, and a >100v 1A diode should be very easy to find in that package.
The running current of those little shaver motors is not very high, maybe 200-300mA average so even a 500mA diode might be ok, although I would try for a 1A diode if possible.
The 8pin FET is a standard package and you can get the spec figures from a A2719 datasheet. If not, then a >=50v FET in about 6A or 8A rating is common in that 8pin SOIC package.
nidzo
Joined Nov 2, 2013
4
Well thank you very much for even late reply :). I have beeing looking for a place online where to buy A2719 without luck. I currently live in Germany but don't speak German language so well. Any ideas where I could order this IC? Thanks for your help once again.
