1) Most of them are.SMPS seem to be an option but I am not familiar enough with them to know if they are properly isolated.
You don't need to worry about that. It will put out whatever current your circuit needs.I only want 300ma though not 1500.
What is it's peak voltage setting? Unless it's already capable of 24 VDC output getting it to 28 VDC is highly unlikely without doing a bit of transformer rewind and voltage feedback loop rework.I have a Quantaray SMPS which I got for a digital camera I don't use now. I opened it out of curiosity and found it had pads and switch contacts for multiple resistors/voltage settings. As provided it was 6v@1500ma. with the resistor in the second to last of 6 positions. I wonder how adjustable this might be. If it would do 5-6-9-12-15-24v for instance maybe it could be adjusted to 28? I only want 300ma though not 1500.
