It's still me buddy.... and we never saw Rif@@ again...
Enjoy your new board!
This suggests to me that your board and the software is all working well.J1 & J2 are in the middle per indication.
J8 & J9 are the same as for 40 pin one.
LINK led is active and as I hit program any way all the LED's work as they are supposed to. But I get programing error.
I checked all the examples and the 40 pin PIC works per example
I got to hand it to you Mr.RB.The PIC is fine! The 16F628A has a LVP pin, I think it is RB4.
To program it you set the pullups jumper for PORTB to "pull down". Then turn on the dipswitch for RB4, to set the pullup resistor to pull-down RB4 to 0v. That will hold the LVP feature OFF, so the PIC programs normally.
If the RB4 pin is allowed to float it can select LVP mode which causes issues with programming. Or if the RB4 pullup is pulling UP to 5v it forces LVP mode on for sure.
by Jake Hertz
by Jake Hertz
by Duane Benson
by Jerry Twomey
