Thank you so much for that detailed guide! Very impressive thank you.Here's a similar schematic to what you're doing, mirroring somewhat the board layout. When positioning the connectors, the pin numbers are important.... well, at least I'd keep the connections the same. Pin 1 connected to pin 1. One of the connectors is rotated 180 degrees compared to the other and I've shown where the pins are.
It's equally valid to draw it without representing placement on the circuit board. In the version below, I flipped one of the connectors over to align pin 1 for a cleaner-looking schematic. The end result will be the same in either case.
When you "convert to PCB", the components are dumped onto a bare canvas for the circuit board. The thin blue "air wires" show which pads are connected to which. Sometimes it can be difficult to tell what goes where - hitting H will show all the connections of the net.
From there, start to position the components as you like. Highlight each net to see where the connections go if need be. Notice that if the connectors are rotated with respect to each other, the pins don't align across the board.
Next, route the tracks. You can only connect pads as shown in the schematic (without editing). If a track won't connect to a pad, it's not supposed to be connected. You can connect the pads by a cirtuitious route, or you could take a more direct path on the bottom layer of the board.
I would still recommend each LED has its own series resistor rather than operating them on parallel. LEDs don't always share current gracefully, and by having independent current limiting resistors, you can add or subtract LEDs from the chain as desired.
thumbs upThis addresses all of the above, and probably eliminates the need for the power board completely.
