Dave, I think the problem is that you are mixing up ideal components and real ones.
The planet is no more a real electrical earth than a wire is a perfect conductor. Real wires have resistance.
Real earths can be disturbed by electrical input. Since planets are large bodies there are many local effects. There can be a local momentary raising of potential by tens of thousands of volts at the point of a lightning strike.
In the same way you will get noise and hum injected into the input of an audio amplifier if you lay out the input (low currrent) and output (high current) earth paths through a common section of track.
Yes a planet will pass a current or a signal according to Ohm's law, like anything else.
But an ideal earth in circuit theory is simply a body that does not change its potential, whatever the current. Planets are usually adequate approximations to this.
