Razor Concepts
- Joined Oct 7, 2008
- 214
Color does not matter.
The tutorial shows you how the auto routing is done.
After you are done routing, there is a button on the left toolbar called "Show/hide layers". Click "none" to disable all layers, and then select "Bottom", "Pads", "Vias", and "Dimension". Click OK. That should leave you with all the traces on the bottom side of the board. Go to file print and it's done!
Note that all the traces must be on the bottom layer. You must set the autorouter so that it does not route on the top layer.
If it helps, I have attached the routed board file.
