I love you. I had no idea how clean it would look. Any chance I could get a peek at the underside?Nice job.
Is this the look you have in your mind?
Of course you can.I love you. I had no idea how clean it would look. Any chance I could get a peek at the underside?
I'm using eagle3d to make a script-file. This file I'm rendering with PovRay.Also, what program did you use? I primarily use SolidWorks and 3DSMAX for my 3D work and then render in Maxwell. Do you know of a way to export .brd or .sch to these programs?
Like those two traces running through the holesI find this very useful, because then I can see how the board will look like when its done.
Excactly, and it looks like the LEDs are not connected with both legs...Like those two traces running through the holes
Are you looking at the edges of the ground plane? Eagle3D/POVray doesn't fill in copper pour areas, so the outline can be somewhat confusing if you don't realize what it is.Like those two traces running through the holes
This is a good catch, as the +V supply to the LEDs has been routed on the top of the board. That will not work well for a home-made board, but will be fine for a commercially-made PCB that has thru-plated pads and vias. Even so, if our OP decides that they need to make some changes on a board that's already been made, it would be easier to have the traces on the side of the board that is accessible.Excactly, and it looks like the LEDs are not connected with both legs...
DIP IC's won't be a problem whether the board is made at home or commercially; as you can solder the pins from the top and the bottom; you would only need to solder from the bottom on a commercial board.Looking at the board again, I see that the LEDs are soldered on both sides. I think this will be hard to do. The same goes for all of the ICs.
Definitely sending it off to a manufacturer. There's no way I'd be able to do this, especially with those traces so close as you mentioned. I have a small group of people who want to do a group buy, so the price shouldn't be too outrageous.Are you going to make this board yourself, or are you planning to send it off some manufacturer?
Reason for asking this is that I think some of the traces are dangerously close to some of the pads.
by Jake Hertz
by Jake Hertz
by Aaron Carman
by Duane Benson
