There is a small difference between packages that are nominally the same in Eagle.
To take just one example, if one compares the SO-08 package from Linear with the SO-08 from Maxim, the Maxim package is a little wider and the pads are a little bigger. Is there a "correct" version?
While on this topic, what is the difference between 8-pin versions of SOIC, SOP (used by Fairchild for LM555), and SO-08 (used by Harris and others for the identical chip)?
Thanks. John
Thanks. John
