Yes, much better!How about this? Better?
The pitch is not 0.1" on the header you used. If you use standard and non-standard components, you will have trouble routing the traces properly. I would suggest trying to find a different header, preferably one in this style or the like:No I was trying to use a standard 12 pin
Okay, not bad for a first try! I only have three suggestions:Ok here's me trying to figure this out.
Okay, I think you misunderstood. T connections are fine, just avoid L connections. Use small 45° angles for the corners. Here's the quick one I threw together last night, just as a quick example.Also, avoid non-45° angles like the ones you have connecting your resistors to your header.Ok I tried to do what you said, and changed a few things and the power form the jack
Would screen shots be sufficient? Also, why not just install Eagle?Can someone update the thread with a PDF so that those without Eagle can see the project as it stands?
I don't expect you would have much of a heat problem, but yes--half of each resistor is still out in the open, not directly next to another one. This will help, if for any reason they do become warm. If you were trying to draw more current, I'd space them out an extra .05", but I don't think you have to worry about that here.So by staggering the resistors like you did it will help with heat dissipation, even though they are that close together?
Great! I suggest trying to lay it out a little differently though, if you plan on actually having it made. Perhaps design it so you can have all the pins on one end/side, to make for easier connection. Be creative, experiment. That's half the fun of designing PCBsOk after looking at your brd its starting to make so much more sense
I believe the 2 and 3 pins are both ground, so yes--you can. But it's not necessary.On the barrel jack can I connect the 2 and 3 pins? I have seen some other schematics that did this
by Jake Hertz
by Aaron Carman
by Jake Hertz
by Aaron Carman
