I have 2 home networks. one internet, and the other is just a test network in one room. The computer I'm using connects to both networks. internet via USB WIFI, the room network by cat 5E. For simplicity I made them both with identical network IDs, with standard class C net mask. the internet LAN uses DHCP from Wi-Fi router set to a small range like 2-15. the wired network in the room uses 100-150. the original setup was all done statically and I had no issues, but after adding DHCP from an old router. and going DHCP on my system it failed to connect to the internet. even after release and renew with the other network then shut off. thinking maybe something to do with same network id on 2 interface maybe it's trying wrong network. disable the LAN interface it works, re-enable it still works. I think the I.P on the lan may not have released during release/ renew.
so what I'm wondering is there anyway to make this work with out changing one network I.D? would think it would work and try both till get response, or one then the other. so it should still work.
anybody know of anyway I can change a setting on the computer to tell what network to use first, or how to alter the routing table so that the address ranges point to different interfaces if this is possible. since normal routing tables don't usually go beyond network id for criteria.
not a big deal to change ID, but this got me curios.
