Driving relay with security light motion sensor
3ds3
Joined Jun 15, 2013
6
I'm using a motion sensor for security lighting to drive a relay to break a circuit.
It works but only for a few operational cycles of the device, when the motion detector trips and breaks the circuit.
I believe it has to do with the current/voltage spikes that occur during each cycle feeding back into the motion sensor causing it to "trip"
electronis whiz
Joined Jul 29, 2010
512
the lamps normally have relays in them to trigger the lamp. hard to tell if your using external relay or integrated one. I would look into the settings on the sensor. sensitivity, timer, etc. possible your using a relay that's too big for it. they seem to use like an average size electronics relay. like you may find in a UPS, car systems like windows wipers, fan. these normally run like 9-12V DC I believe that's what these sensors use too. you may need to use a small reed relay to trigger bigger one, or use some form of power transistor.
3ds3
Joined Jun 15, 2013
6
The sensor runs on 120 volts
The relay runs on 120 volts
I believe the sensor has a triac, based on that it would not operate the relay without a 500 ohm resistor to draw enough current to latch the triac closed.
I even tried a 450 micro farad cap to try and ease the surges but it seems to not really help.
Dodgydave
Joined Jun 22, 2012
11,307
Its possibly the relay taking too much current when dropping out, your Sensor will use a zero voltage detector opto Triac , you will have to slave another triac to fire the lamp, or smaller relay coil.
3ds3
Joined Jun 15, 2013
6
The coil is 4.3 meg ohms.
The triac would not energize the coil because the minimum latching current for the triac was not met
